Creating User Levels SA 2.0.5
Thread begun 6/21/2012 6:24 am by johna1964 | Last modified 6/21/2012 8:35 am by johna1964 | 1235 views | 2 replies |
johna1964
I am trying to understand how to implement the Administrator and Power User levels.
Step by step:
1) Open login.php page
2) Double click on Security Assist Authenticate User to open Authenicate User dialog box
3) Select Database tab; plus button; then, userLevel
What do I select for the value?
Do I need to next, select the Session Value tab and add userLevel session variable and session name?
Then, I repeat all of the above for the automatic login SA Authenticate User?
Thank you!
johna1964
this step is not necessary.
Go to the Session Tab to have the UserLevel Column stored as a session on login.
you then create an access rule that compares the value of the user Level session to determine if the user is a Admin or Supper user
johna1964
Thank you!
johna1964
