Manage Relational Table Issue
Thread begun 6/21/2012 3:13 am by JPowell | Last modified 7/19/2012 1:27 pm by Andrew Read | 7031 views | 23 replies |
JPowell
Has anyone tried a manage relational table with Data Bridge? I had no problems with this using Data Assist, but now, with Data Bridge, it does not seem to work. Upon updating on the attached update page, the Options_Table_Foriegn_Key of the many to many table is updated properly, but the Main_Table_Foriegn_Key records a zero. The insert page does not work either but I have just attached the update page.
Rune Brynestad
Are there any solution for this. I have the same problem too.
The key value from the main table join writes to the relational table as it should, but the options form field value does not. It writes the value 0 to the database, not the value from the form field.
I'm attaching my page.
Live URL here: Kunde_skjema.php
I also get the attached error message after I have picked the "Go to" file. Deleting the winfile cache does not help.
Regards
Rune
JPowell
Jason, thanks for creating the support ticket. Due to time difference though, it is hard to find a time which matches your tech support call line. I will reply to the support ticket, but as Rune just confirmed, there is a problem and it would be easier if it was simply fixed.
I did a little more experimentation and found something interesting. Let's say the many to many table is set up like this. id, options_id, main_id. For me, when I insert a record, options_id is fine, but like Rune said, main_id is 0. Then I modified the table to be id, options_id, main_id, pricediff_id - adding the pricecdiff additional field. In the relational table wizard, I set the pricediff_id to a random number. Now the main_id data is writing into the pricediff_id and main_id is still 0.
I will wake up early and get with your engineers early next week.
You and Rune are the only two people to report the issue. We will need to look into the problem with either of you to find a cause and implement a solution, though the solution for rune may not be the same solution for you.
I am looking at the support incident I started, and there has not been a reply yet, please please reply with contact details so we can investigate the issue.
We have identified the issue with the manage relational table behavior.
here is an updated copy of the webassist/database_management/wa_appbuilder_php.php that will correct the problem
Rune Brynestad
I believe there is another issue with the manage relational table behavior. As far as I can see, the fix works if there is only one manage relational table behavior on the page. I have an Insert page with two manage relational table behaviors. Only the last one added works. For the first one, nothing is written to the relational table. The second one works as it should.
I'm attaching my page. It's a Product Insert page with size (størrelser) and color (farger) options. In this case, only the color (farge) is inserted into the relational table.
I'm also attaching the wa_appbuilder_php.php page that I'm using.
Live URL here: products_insert.php
Regards
Rune
using 2 columns in the product options table, one for size and another for color, then using two manage relational table behaviors is not the correct way to accomplish this.
for multiple option types, the database structure would be:
optiongroups:
optionGroupID - Primary key
optionGroupName
example:
| optionGroupID | optionGroupName |
| 1 | Color |
| 2 | Size |
options:
optionID - Primary Key
optionGroupID - Relates to optiongroups.optionGroupID
optionName
example:
| optionID | optionGroupID | optionName |
| 1 | 1 | Red |
| 2 | 1 | Yellow |
| 3 | 1 | Blue |
| 4 | 1 | Green |
| 5 | 2 | Small |
| 6 | 2 | Medium |
| 7 | 2 | Large |
in the product options you only have one option column to use in the manage relational table behavior.
in your page, use one recordset to return the options, and one repeat region, set the recordset to order by optionGroupID, then you can add an if statement to change the label to Size if the optionGroupID = 2
Rune Brynestad
So I only need one manage relational table behavior on my page ? Not one for the size and one for the color?
I believe I need two set of checkboxes, one for the color and one for the size. Can booth be inserted with one manage relational table behavior ?
Regards
Rune
