Not all pins are showing
Thread begun 6/20/2012 2:52 pm by brian358606 | Last modified 6/22/2012 4:39 pm by brian358606 | 1858 views | 2 replies |
brian358606
I have installed Design Extender 1.0.8 and am using Pro Maps for Google.
Here is the site: map_Madrid.php
I have six recordsets that run with each assigned a different pin, flag or star. My problem is that not all the locations are showing.
A particularly confusing piece is that the recordset "Sights" which is represented by a 'star' shows up some times and other times not. There are three "Sights" locations. When the star shows at all, it only shows one 'star' location, but not always the same one - each time I refresh may be a different 'star' location, but never more than one, and many times none. I have another recordset for restaurants, and the 'flag' icon for the one restaurant does not show at all - it has a complete street address.
brian358606
Problem solved
I rebuild the pages from scratch. They work properly now and I have moved the temporary file location to a public section.
brian358606
Resolved problem by switching to geocoding
After several different attempts with using actual street address, I added geocoding to each address. Apparently Google maps was having problems with some of my address, and it repeatedly affected the reliability of the maps. Different refreshes would produce different pins showing up. I should add that the addresses were all European, and even after removing foreign accents, it appears Goggle's problems in finding the addresses cause problems. But switching from addresses to geocodes all of the problems disappeared immediately, and finally all the pins/flags/pillows were properly displayed.
