Posting to more that one table
Thread begun 8/03/2009 6:27 am by cherylrusche378937 | Last modified 8/03/2009 3:49 pm by Jason Byrnes | 2232 views | 1 replies |
cherylrusche378937
I am trying to post to more than one table using DataAssist. I keep getting a "Internal Server Error".
My parent table is teams and the child is team_name. I need to insert the team name into the column "teamname" and the id from the table "teams" into team_id.
I have included the dreamweaver page.
You need to add an insert record server behavior for each table you wish to insert to.
The first one should insert to the teams table. In the session variable section, select the ID column for the teams table, this will save the inserted records ID to the session variable. Make sure to leave the redirect after insert option blank.
The second one will insert to the teamname table. Bind the team_id to the session variable created by the first insert record server behavior.
If you are still having a problem, make sure you are not testing using IE, IE sometimes will not post the real error that is occurring.
