Install problems
Thread began 6/20/2012 10:29 am by hcumens08179986 | Last modified 6/20/2012 10:37 am by Jason Byrnes | 461 views | 1 replies |
hcumens08179986
Install problems
Hello. When I go to "webassist" - "add content to powerCMS", I ge the following error:
"Unable to edit your database with the provided user credentials. Please make sure the connection user has write access to this database."
The databse connection tests correctly in Dreamweaver and I have verified with the host that the connection and settings are correct. Is there another way to upload the PowerCMS files to the website and install the admin area.
I have PowerCMS builder and have installed it a year or so ago on another site.
What other information do you need to assist me?
thanks!
this error usually happens if there is a problem with the site Definition settings to connect to the Testing Server.
In the site definition, double check the testing server settings, if you are using an FTP connection to the testing server, make sure to set the host directory if one is needed and Double check that the testing server URL is correct.
