Priority - validated vs session variable?
Thread begun 6/20/2012 7:49 am by msummers194171 | Last modified 6/21/2012 8:41 am by Jason Byrnes | 4344 views | 9 replies |
msummers194171
On my eCart4 site, the checkout page leads to the confirmation page (as usual). In my case, the fields on the checkout page look like this -
<td><input type="text" name="firstname" id="firstname" value="<?php echo(ValidatedField("confirm","firstname")) ?>" /></td>
When you then click on the CHECKOUT button on the checkout page, you are taken to the confirm.php page where session variables are loaded containing the POSTed data. If you want to make a modification to the cart's contents, and click on the MODIFY button (which returns you to the checkout page with a javascript backup in the history), the fields are blank. I'd like to populate those fields with the originally posted data. How should the modified fields look to do that? Should I give priority to the session variables or to the validated field data?
Thanks!
the validated entries will only be set if the form fails validation.
In the validation server behaviors, set the failed redirect to go back to the checkout page and pass "failed=true" as a querystring variable:
checkout.php?failed=true
and use a ternary expresion to use the validated entries based on the query srting:
value="<?php echo((isset($_GET['failed']))?(ValidatedField("confirm","firstname")):(isset($_SESSION['eCartCheckoutForm_firstname'])?$_SESSION['eCartCheckoutForm_firstname']:"")); ?>"
msummers194171
Jason, thanks. Can you recommend what to do for the <select> tags? They currently have something like this -
<?php if (!(strcmp("MasterCard", (ValidatedField("confirm","cc_type"))))) {echo "selected=\"selected\"";} ?>
for a select list, click the dynamic button in the property inspector, and use the following code for the Select Value Equal To option:
<?php ((isset($_GET['failed']))?(ValidatedField("confirm","cc_type")):(isset($_SESSION['eCartCheckoutForm_cc_type'])?$_SESSION['eCartCheckoutForm_cc_type']:"")) ?>
msummers194171
So, it would be -
<?php if(((isset($_GET['failed']))?(ValidatedField("confirm","cc_type")):(isset($_SESSION['eCartCheckoutForm_cc_type'])?$_SESSION['eCartCheckoutForm_cc_type']:""))) { echo 'selected="selected"'; } ?>
is that right?
no, that doesnt look right.
dont edit the code directly, use the dynamic button in the property inspector, and input the code i gave for the select value equal to option, let dreamweaver generate the code for each option.
msummers194171
But I'm doing this on a box that doesn't have the extension installed. :(
doesn't mater if the extension is installed, the code I gave will do the trick if you paste it to the Select Value equal To section in the Select Lists Dynamic Properties.
msummers194171
Thanks - looks like that works. Here's a head-up for you. You can update <select> tags as you describe, BUT if the <select> tag contains an <optgroup>, the updating will stop at that tag and ignore the rest of the <option> tags within that <select>. If you want to do the full <select> tag, you will have to remove the <optgroup> tags first and then replace them.
Yes, the Dreamweaver interface does not have support for optgroups, so wont recognize them.
