setting CSS for menu item corresponding to page
Thread begun 8/02/2009 5:27 pm by bill.dawes319233 | Last modified 6/03/2010 2:35 pm by Jimmy Wu | 3741 views | 3 replies |
bill.dawes319233
I might be being really stupid here, and missing something blindingly obvious. Is there a quick and easy way to make this (otherwise excellent!) system work so that the menu displays the
ul#cssmw > li > a:active
CSS for the link that corresponds to the page (or page group) that the menu is actually on?
I could hack out a php script to get the URL of the page and see if it corresponds to the link address, and if so, change the style of that particular LI tag. But before I get dirty with that, am I missing some existing function or simple setting change?
Jimmy Wu
There is a setting for Menu Writer that will show the current page as selected in the menu. If you click on the menu and edit theme (or create a new menu and select define next to Theme), go to the design tab and the Current tab under Background & Border, you can set the select in menu settings to be the page you're on.
shanti351931
I have no current tab
I have no current tab under this section. Is it my version? 1.0.4
Jimmy Wu
Yes, you will only have that tab if you are working in Menu Writer V2.
