ProductStartDate & End Date
Thread begun 6/17/2012 11:27 am by SuperSoaker | Last modified 6/21/2012 8:30 am by Jason Byrnes | 3799 views | 8 replies |
SuperSoaker
In my search page what value do i use to get "current date"? and can I add "time" to the search page and how to combine date and time on the insert or update form? This will allow the client to choose start and end dates and times
Thanks Jason
to get current date use the following code:
<?php echo(date("m/d/Y"); ?>
using time in your search depends on how the data base is set up, if you want to have a separate input for date and another for time in your search, you will need 2 separate fields in the database. one set to use the Date data type, and the other set to use the Time data type.
SuperSoaker
Does date and time need to been inner joined
Jason,
How would I bind the date and time, my search is using AND so it needs to be start date = date and time and end would be same,
To enable my client enter start and stop date and time
Jason really appricate your help
SuperSoaker
Added recommended code - got error
I added the <?php echo(date("m/d/Y"); ?> to the value of startDate and endDate, throws a syntax error. I added this in the DataAssist search popup box.
Not sure if it makes a difference the date format in my database is year/Month/Day and the trigger is Before Page Load. Basically I have a page display items display from category AND date start AND date end
code is missing a ):
<?php echo(date("m/d/Y")); ?>
if the format in your database is year/Month/Day
then the date code should use that format to:
<?php echo(date("Y/m/d")); ?>
see this page for formatting information:
function.date.php
SuperSoaker
Still not working
products_results2.php this is the page link, with the setting i have 1 tounament should show (march tourn)
Please help
start and end date to display
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
SuperSoaker
No Errors
I put in the error reporting code, no errors?
My search works fine with TournamentDisplayStart and take out the TournamentDisplayEnd, but when it's in place with a Lessor Than or equal it's blank? I'm using AND as my separator?
