Reverse Sort Order
Thread began 6/15/2012 12:36 pm by MikeyT | Last modified 6/18/2012 6:50 am by MikeyT | 832 views | 2 replies |
MikeyT
Reverse Sort Order
I have a results page on the front end that is displaying news article headlines. When adding new headlines, the newer ones end up at the bottom of the list, then eventually on the last page. Is there a way to reverse the display order so that the newest headlines are always at the top/on the first page?
I thought I read a thread on here somewhere with a similar problem, but I can't seem to find it. any help is appreciated. Thanks.
you would need to edit the recordset and add an ORDER BY clause.
SELECT * FROM table ORDER BY columnName ASC
MikeyT
Thanks Jason. I forgot to mention that I have the recordset sorted by date. If I change ASC to DESC in the sql clause, all seems to work out.
