Possible Bug in "HTML Editor Quick Insert"
Thread begun 6/14/2012 9:50 am by Willi Schneider | Last modified 6/14/2012 12:17 pm by Jason Byrnes | 1153 views | 1 replies |
Willi Schneider
Hi WA-Team
I found a possible bug with HTML Editor in the new DataBridge v1.04
When running the DA wizard to create the insert/update pages, I have one or more HTML editor instances, which get created fine.
When I now try to edit the HTML editor settings to, for example, "Full File Managment", the source code of my page gets corrupted.
Instead of:
<span>
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".((isset($_GET["invalid"])?ValidatedField("ansprechpartnerupdate","AufgabenAnsprechpartner"):"".$row_WADAansprechpartner["AufgabenAnsprechpartner"]."")) ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "Advanced Manager Enabled";
$CKEditor_config["wa_preset_file"] = "AdvancedManagerEnabled.xml";
$CKEditor_config["width"] = "800px";
$CKEditor_config["height"] = "400px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["filebrowserBrowseUrl"] = "../../webassist/kfm/index.php?uicolor=".urlencode(isset($CKEditor_config["uiColor"])?str_replace("#","#",$CKEditor_config["uiColor"]):"#eee")."&theme=webassist_v2&showsidebar=false";
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','Print','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks','-','About'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("AufgabenAnsprechpartner", $CKEditor_initialValue, $CKEditor_config);
</span>
I get this:
<span
> </span>
So, in short words: The code for the HTML Editor instance gets placed inside the opening "<span>"-Tag.
Additional system info:
  • Win XP SP3
  • DW CS4 and CS5
  • Latest Data Bridge (1.04)
  • Latest Design Extender (1.08)
  • Uninstalled older versions prior to updating
  • deleted DWFileCache
  • reset work space
Any info would be greatly appreciated.
Greetings
Willi
I have not been able to reproduce the problem. I have created a support ticket so we can look into this issue further.
