Powerstore Installation error
Thread begun 6/13/2012 12:03 pm by vallvic484439914 | Last modified 6/28/2013 9:33 pm by vallvic484439914 | 2495 views | 6 replies |
vallvic484439914
I installed powerstore the way the video tutorial showed me and everything worked fine up until I finished the installation wizard I got this error.
Warning: require_once(../webassist/themes/theme_open.php) [function.require-once]: failed to open stream: No such file or directory in D:\hosting\8727527\html\v2fineinteriors.com\admin\home.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../webassist/themes/theme_open.php' (include_path='.;C:\php5\pear') in D:\hosting\8727527\html\v2fineinteriors.com\admin\home.php on line 1
Thanks in advance for the help!
vallvic484439914
Private message
Originally Said By: vallvic484439914
  Private message
vallvic484439914
Private message
vallvic484439914
By the way these problems started because I went form a Microsoft server to Linux which gave me problems then i switched back to eliminate the problems which all did except it created this new problem.
vallvic484439914
Never mind I just FIXED the problem!!
Thanks for the help.
Victor
