PS 4.5.3 Update Issue
Thread began 6/11/2012 2:24 pm by Dan808 | Last modified 6/12/2012 7:42 am by Jason Byrnes | 666 views | 2 replies |
Dan808
Just uploaded PS 4.5.3 to wheezingeezer.com and I am getting an error on the home page now.
Error reads:
Warning: require_once(initialise.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/03/8488303/html/index.php on line 56
Fatal error: require_once() [function.require]: Failed opening required 'initialise.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/03/8488303/html/index.php on line 56
Dan808
Just to follow up to my last post... I uploaded the backup I created so that the store would be available. I will do the PS 4.5.3 update again and see if it goes better the second time around. If you have an answer as to what happened I would sure appreciate knowing so I can avoid the same result as the previous post.
Thank you WebAssist
from the error, it looks like you uploaded an index.php page to the root of your site that was intended to go in another directory.
the Power Store root index.php file does not have a require once statement at line 56.
