File not uploading
Thread begun 6/11/2012 11:59 am by rgolab68503 | Last modified 6/11/2012 1:57 pm by rgolab68503 | 2835 views | 5 replies |
rgolab68503
File not uploading
I have been going through the forums to see if I can get my file to upload and have tried several things to try to make it work. I have even entered in the error debugging code, which I put into my Admin_Insert.php page. This is the results I have when I entered that code:
Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
WA_UploadResult1_2:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
I still can't get the file to upload.
Just to be sure I am clear on what I am trying to do is I am simply asking it to get a file which I browse to. It them uploads it to two different folders at two different sizes however retains the original name of the file which is the product code.
Any ideas where I have gone wrong?
to make sure it is not a php error causing the problem, add the following code at line 1:
error_reporting
(E_ALL);
rgolab68503
File not uploading
This is what is comming up.
Notice: A session had already been started - ignoring session_start() in /var/www/html/toyo_support_site/support/POP/adminT/Admin_Insert.php on line 223
ShareThis
rgolab68503
file not uploading
To try and isolate this I created another simple file that simply is called uploads.php. It goes nowhere but does have the same upload settings. I also added the error reporting code to the top of this page. This is what comes up.
Warning: move_uploaded_file(/var/www/html/toyo_support_site/support/POP/adminT/../Images/4dc3ac702b03b8f44d46c12b879df1ba_tmp.jpg) [function.move-uploaded-file]: failed to open stream: Permission denied in /var/www/html/toyo_support_site/webassist/file_manipulation/helperphp.php on line 94
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/tmp/phpBvDRbF' to '/var/www/html/toyo_support_site/support/POP/adminT/../Images/4dc3ac702b03b8f44d46c12b879df1ba_tmp.jpg' in /var/www/html/toyo_support_site/webassist/file_manipulation/helperphp.php on line 94
Warning: copy(/var/www/html/toyo_support_site/support/POP/adminT/../Images/4dc3ac702b03b8f44d46c12b879df1ba_tmp.jpg) [function.copy]: failed to open stream: No such file or directory in /var/www/html/toyo_support_site/webassist/file_manipulation/helperphp.php on line 96
The directory is already there so it deosn't need to create it.
the error means that the upload directory /Images/, does not have sufficient write privileges for the file to be saved there. You will need to edit the privilege level of the /Images/ folder to allow write access.
rgolab68503
Thanks I'll have to talk to my service provider to adjust this.
