Customer Complaints and inqueries
Thread begun 6/11/2012 11:41 am by admin140217 | Last modified 6/12/2012 7:14 am by Jason Byrnes | 879 views | 1 replies |
admin140217
Hello,
I have a client who is using PS4.5 and the one compaint she has is that when she is trying to style links using the designer tool, she doesn't know which section to select from the drop down to change an element of the sites design such as background colors on heading or hover color for links and do on.
She wants to know if there is a manual with regard to what changes what in which section of the designer to control link elements and so.
In the design Editor, You Can edit Colors, Images, And Fonts.
If you select to edit colors, the "View Colors Of" Dropdown list allows you to select various aspects of the site. To Change Links, Select Global Styles.
Under Global Styles, the sixth option down is Links. There are 2 column, back ground and text. the text column allows you to change the color of the text links.
Under the lin ks option, you can change the hover colors as well.
