A few questions
Thread begun 6/10/2012 9:55 pm by lr_leal239405 | Last modified 6/11/2012 7:33 pm by lr_leal239405 | 1315 views | 2 replies |
lr_leal239405
A few questions
I have a few questions on editing the powerstore:
1) I use retail price to show on the product results page, but I want to change the wording to say 'retail' instead of 'retail price'. I can't find where that is although I looked for quite some time through several pages, the database and the themes settings xml.
2) Since I'm giving the Administrator (my client) the ability to edit the Design, they can see all the original themes. So I took them all off but how come when I delete the 'Default' theme I start getting error messages. Why do I need to keep the default?
3) My client is selling food products form south america so I added some countries to the categories. Then I added the subcategories and the products inside those, but when I click on the country name the search results finds nothing. Only by clicking on the subcategory does it find it. That's wrong. It should find all the products in the subcategories that pertain to the main category. How do I change that?
4) You have a glith in your system. I added my client as an administrator. But when I go to update with all the info in the fields and submit, the validation "Please enter a first name" comes up on the right side of the password. It should of course be on the right side of the First Name but in my case it shouldn't pop up at all because the First Name and the rest of the fields are all filled in. ??
Thank you.
1) That is on the webassist/plugins/catalog/details.php page
2) The default theme is the main theme, any of the other themes can be deleted, but the default theme is used as the default when the editir is opened without first selecting a theme.
3) On the products update page, you can set the categories the product belongs to, if you want to show the product when the main category is selected, you need to select the main category as well as the sub category
4) I have created a support ticket so we can look into this issue further.
lr_leal239405
1) I found it on several pages that were on the server, in the folder you pointed out, but not on my local drive even though I had copied all the files down before looking. I guess new files are created dynamically when some changes are made? otherwise I don't know why they didn't copy down which is why I couldn't find the files.
2) Ok. Maybe I can make it not visible. thanks.
3) There was nothing obvious that would tell me how to do it. I ended up shift+selecting, updating, and, yes, it worked that way.
