Pin not showing
Thread begun 6/08/2012 8:02 am by JamieEff | Last modified 6/08/2012 9:55 am by Jason Byrnes | 3883 views | 6 replies |
JamieEff
Pin not showing
Hi
Have installed a map on a site and on the live site, the push pin is not showing but everything else is...
I have checked paths and file locations and they all *seem* to be ok....
Cheers
Jamie
please post a link where i can see the problem.
Is this using the stand alone pro maps? or the Pro Maps in Design Extender.
If you are using design Extender, make sure you have installed the 1.0.7 update, there was a bug with paths to the icons in the previous version that is fixed in 1.0.7.
JamieEff
thanks Jason, installing 1.0.7 right now.
Jamie
JamieEff
Ok, have uninstalled and installed the latest version and now the pin is showing - thanks for that.
However, the bubble is showing despite me checking the driving directions bit and leaving it all blank....
Jamie
EDIT... Have removed and re-added the Google code 4 times now and every time it still keeps the bubble..
that trick does not work in the new V3 API that is used by Design Extender.
in the google_javascript folder, open the map JS file.
look for the following code:
// open info window for default address
if (isDefault) {
infowindow.open(map1,marker);
map1.setCenter(point);
the reference to map1 may be different in your file, and comment the infowindow.open(map1,marker); line:
if (isDefault) {
//infowindow.open(map1,marker);
JamieEff
great... thats done it! Thanks
Just for future reference, do we then need to carry on selecting directions and leaving blank or is it just a question of commenting out that one line from now on?
Cheers
Jamie
In the V3 API used by design Extender, you need to comment that one line.
JamieEff
just installed a google maps and that line was already commented out but the comment bubble is still showing...
What could be wrong with it?
Cheers
Jamie
I'll need a link to see the problem so i can investigate.
JamieEff
here you go Jason: contact.php
