Add To Cart - Blank Page
Thread began 6/08/2012 6:42 am by peterm.bruce341471 | Last modified 6/08/2012 9:43 am by Jason Byrnes | 2368 views | 4 replies |
peterm.bruce341471
Developing in php environment, mac using mamp everything working well in my site until I introduce ecart. Did everything as per guide, carefully set up the cart, checkout etc.
I introduced an add to cart button to my page now the page loads and it's blank. Obviously one of the includes is having problems but I can't see where or what. Any ideas?
Thanks,
Peter
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
peterm.bruce341471
This post has been deleted.
instead of using virtual for the include files, require once should be used.
In your site definition, There is a setting for "Links Relative To" this can be set to "Document" or "Server"
Using "Server" will cause Dreamweaver to use the virtual() function for include files, this can be problematic.
I recommend using "Document" relative links so that Dreamweaver will use the require_once() function for include files.
peterm.bruce341471
Sorted
I've changed the includes manually in all files - seems to be working.
Great job and thanks for the advise - next time I'll be sure to define the site as you say.
Thanks Jason.
glad to hear it is working.
