Delete record : Not working
Thread begun 6/08/2012 5:46 am by MikeH | Last modified 6/08/2012 8:51 am by Jason Byrnes | 1814 views | 3 replies |
MikeH
Hi
I am using the latest build yet the delete record is not doing anything.
3 image files are deleted first and then the record delte is actioned if the trigger delte 3 successful (all 3 files are deleted successfully).
But thats it the delete record does not action. (code below)
Any ideas?
Thanks Mike
<?php require_once('../../Connections/Totalheadturners.php'); ?>
require_once("../../webassist/file_manipulation/helperphp.php"); ?>
require_once("../../webassist/database_management/wa_appbuilder_php.php"); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (
PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return
$theValue;
$colname_RsImageDetails = "-1";
if (isset(
$_GET['imageid'])) {
$colname_RsImageDetails = $_GET['imageid'];
mysql_select_db($database_Totalheadturners, $Totalheadturners);
$query_RsImageDetails = sprintf("SELECT * FROM CarImages WHERE Id = %s", GetSQLValueString($colname_RsImageDetails, "int"));
$RsImageDetails = mysql_query($query_RsImageDetails, $Totalheadturners) or die(mysql_error());
$row_RsImageDetails = mysql_fetch_assoc($RsImageDetails);
$totalRows_RsImageDetails = mysql_num_rows($RsImageDetails);?>
// WA Application Builder Delete
if ($WA_DeleteFileResult3) // Trigger
$WA_connection = $Totalheadturners;
$WA_table = "CarImages";
$WA_redirectURL = "../admin_list_images.php?carid=".$row_RsImageDetails['CarLink']  ."";
  if (
function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "Id";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".$_GET['imageid']  ."";
$WA_comparisonStr = "=";
$WA_fieldNames = explode("|", $WA_fieldNamesStr);
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_columns = explode("|", $WA_columnTypesStr);
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_Totalheadturners;
mysql_select_db($WA_connectionDB, $WA_connection);
  if (!
session_id()) session_start();
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
$WA_DeleteFileResult1
= false;
if(
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("../../uploaded_images/", "".$row_RsImageDetails['LargeImage']  ."");
$WA_DeleteFileResult2
= false;
if(
$WA_DeleteFileResult1){
$WA_DeleteFileResult2 = WA_FileAssist_DeleteFile("../../uploaded_images/medium/", "".$row_RsImageDetails['LargeImage']  ."");
= false;
if(
$WA_DeleteFileResult2){
$WA_DeleteFileResult3 = WA_FileAssist_DeleteFile("../../uploaded_images/thumbs/", "".$row_RsImageDetails['LargeImage']  ."");
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
I am record:
<?php echo $_GET['imageid']; ?>
</body>
</html>
mysql_free_result
($RsImageDetails);
the issue is code order.
the code for the delete record behavior comes before the code to delete the files.
to be able to trigger the record delete on the delete file success, the code to delete the file must come before the code to delete the record.
PHP Is processed from top to bottom.
MikeH
Thanks Jason
That worked a charm.
Is this something I did wrong? I inserted the delete file behaviours first then the delete record was inserted last. Or is this just something that is unavoidable when using extensions?
Mike
probably not something you did wrong, the extensions use a weighting system to determine where in the page the code gets added, in more cases than not, the delete record and delete file code order wont be an Issue, usually the delete record would happen first. you just happened on a scenario where the file delete needed to happen first.
