Error creating contact from CSS form builder
Got this error while creating a form using form builder included with databridge. See images.. the "error_2" is the following error after i clicked ok..
the errors are a bit difficult to read.
What version of Data Bridge are you using?
Version 1.0.3 was released yesterday to correct a number of issues, make sure this is the version you have installed.
if you have a previous version, uninstall it from the extension manager before installing the newer one.
also try Deleting the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
Thanks the version update did the trick...
