Databridge error when using the 'Form Validations and Field Setting' in SA
Thread begun 6/07/2012 11:40 am by Nico | Last modified 6/08/2012 9:24 am by Jason Byrnes | 8438 views | 9 replies |
Nico
Hi.
Don't know if this has been resolved but couldn't find any solution.
Everytime I am using Security Assist (though Data Brigde) to create security pages and when I am trying to 'Set up field labels and form validations for the fields in my forms', I am getting the error you see on the attached image.
Am I doing something wrong?
Thank you in advance.
Nico
Additionally wont let me login
If I ignore the error and continue woking, I create the SA pages.
I can register a new user but when I try to login I get a 'user invalid' message.
In the login page I see that exist 2 'Security Assist Authenticate User' server behaviors.
Look at the attached image for further details.
Thank you
PS. Using DWCS5.5 on windows 7
there will be an update made available to data bridge later today or tomorrow that should correct the error you are getting.
the login page is supposed to have 2 authenticate user behaviors.
One is used when the login form is submitted, the other is used when the auto login option is pressed.
send a copy of the registration and login pages so i can look into why the login os not working.
Nico
Thank you
Thank you very much for your fast reply.
I attach the 2 files.
Nico
Thank you
Forgot to attach the files.
Here you go
The update to Data Bridge was just released and should be available in your download center.
Try recreating the security assist pages using the new build Version.
The pages you attached included the user update page, not the registration page. make sure you are registering a new user for testing.
Nico
Still cant login
Hi.
Sorry for including the wrong files.
Recreated the pages. Error doesn't show up but still cant login after registering a user.
Thank you
I see you are using MD5 encryption for the password, double check in the database that the pswd column is set to varchar(40). the MD5 encrypted string is a 40 character string. If the pswd column is not set to allow 40 characters, then it will be truncated in the database causing login to fail.
Nico
I love you
Thank you so much.
Spend two days trying to figure out why it doesn't log in.
Been using varchar 30
Changed to varchar 50 and works perfect
Really thank you for your help
glad to hear it is working.
