Remove spell check?!Or fix it!
Thread begun 6/07/2012 11:00 am by tone397472 | Last modified 2/07/2014 9:16 am by Jason Byrnes | 2791 views | 11 replies |
tone397472
Besides the fact that the spell check doesn't function proper in Dutch is it possible to remove the application from the CMS?!
All text is underlined red all the time and the correction function doesn't work proper (it doesn't recognise the most common simple words!)
I hear this from several clients user Power CMS and noticed it my self.
Is there any thing I can do, because it gives a amateurish impression to have all content text red underlined all the time.
Thanks David
on the admin/contents_update.php and contents_insert/php find the following line:
$CKEditor_config["scayt_autoStartup"] = true;
and change it to:
$CKEditor_config["scayt_autoStartup"] = false;
tone397472
Thanks Jason!
But what does this exactly accomplish?!
David
it disables the Spell Check As you Type (scayt) feature on page load.
tone397472
OK I understand. Thanks for the quick reply!
tone397472
Not working
Hi Jason,
I did a test install of Power CMS 1.01 and changed the code according to your advise to get rid of the Dutch spell check red underscores, but unfortunately it's not working. Can you please come with a solution.
How is this organized in the new CMS!? I need to translate the whole CMS in Dutch any tips!?
Thanks! David
tone397472
Thanks! But where do I find the PM link!?
tone397472
I responded to your mail
the emal uses a doi not respond address.
you should see the private mesage if you are logged in.
if not, send it to my email address:
jbyrnes@webassist.com
