Spacing/Positioning issue
Thread begun 6/06/2012 7:50 am by keith437972 | Last modified 6/06/2012 2:23 pm by Jason Byrnes | 1676 views | 3 replies |
keith437972
I created security pages with Security Assist and attempted to use the Form Builder tool to make some modifications. What I did in the attached screen shots was to try to move the Submit button to the right side of the form but the spacing issues seem to happen anytime I try to use this tool:
-Clicked on the header for the form to get the options in the properties pane
-Clicked the Edit Design Button
-From the dropdown chose Buttons
-From the next dropdown chose Buttons Row
-In Alignment chose Right
-Clicked Apply, Finish & OK to get back
Maybe this isn't intended to move the button to the right and if that's the case I'd like to know that too but the real issue is that once this is done all the fields seem to have double spaced in the form.
The attached screen shots show the original form (single spaced) and the modified form (double spaced).
Thanks.
form builder is a form creation tool, not a form editing tool.
it should not be used to modify the design of existing forms. that is not it's intended use.
to change the positioning of the button on the Security assist registration form, you will need to manually edit the CSS. send a link where i can see the registration form, And I can tell you what needs to be edited.
keith437972
Thanks Jason,
I guess that since the edit form and other buttons show up in the property panel in dreamweaver that I could use them to modify the form.
I only have the files locally but I'll dig into the CSS & make the changes.
The edit option should only be used for forms that where generated using CSS Form Builder to begin with.
