Adding an email confirmation field to registration form & remove second security ques
Thread began 6/05/2012 11:58 am by ruth265305 | Last modified 6/06/2012 10:53 am by ruth265305 | 2187 views | 2 replies |
ruth265305
Hi there,
I need to add an additional form field that confirms the user's email address in addition to the confirm password field that already exists. I can't seem to figure out how to make that happen. Help please?
Also, I need to delete the second security question from the forms... I delete the line, but the validation still kicks in and won't submit the form. Thank you!
Ruth
A confirmation field is a spry validation field.
to add spry field to your form, go to Insert -> Form -> Spry Validation confirm
In the spry settings, set it to use the Email Address element as the comparison.
to remove the security question validation, find the following 2 lines and delete them:
var sprytextfield10 = new Spry.Widget.ValidationTextField("sprytextfield10", "none", {validateOn:["blur"]});
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,8);
These are not supported modifications to power store, if you require additional assistance in making these modifications, please sign up for a premiere support appointment.
ruth265305
thanks!
I'll give it a try... It looks like adding another validation is giving it problems. If I can't figure it out I'll sign up for a support ticket. Thanks.
Ruth
