Nothing happens
Thread begun 6/05/2012 5:59 am by hbibizadeh396670 | Last modified 6/06/2012 3:50 pm by Ian S | 5110 views | 15 replies |
hbibizadeh396670
Nothing happens
I am adding a Friends feature to social network, like facebook.
My system works as follows:
I am trying to create a new record in a table each time the add friend button is clicked.
The table needs to contain the user ids of the user making the friend request and the user who’s profile is being viewed.
I would then filter the data later to create friend lists and so on... I have user registration in place for the IDs... so that is not an issue.
The issue is, when clicking the button, the page just re-loads and does not create a record or do anything.
As the page is supposed to redirect to the index page afterwords, I know that there is an error or I am doing something incorrectly.
Although, I do not understand the issue, as I am an experienced user of these products
Help would be appreciated.
send a copy of your page please so i can see the code.
hbibizadeh396670
Thanks, I have attached a copy.
Ian S
It looks like your server side validation is failing, because you don't have a captcha in the form...
Take out this code....
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "UserProfile.php";
$_SESSION['WAVT_UserProfile_767_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateLE(strtolower($_SESSION['captcha_Security_Code_1']) . "",strtolower(((isset($_POST["Security_Code_1"]))?$_POST["Security_Code_1"]:"")) . "",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"UserProfile_767");
and see if that helps.
The problem looks like submission is failing, but you have not setup any show on fail messages.
Also, on a side note, you are referring to a session value in your validation but have not started sessions on the page (unless they are started in one of the includes)
Cheers
Ian
hbibizadeh396670
Thanks that works, but I have a small issue again.
I need to filter a recordset twice. It need to filter based on a UserID in a form field on the page, and the UserID of the logged in user to see if the database table contains a record with both the users. Hence, they are friends already.
My plan was then to use "show if" to display messages. However I cannot make it work. Is my SQL incorrect?
SELECT *
FROM friends
WHERE UserID = colname AND FriendID = colnamem
colname
$_POST['AddFriend_UserID']
colnamem
$_SESSION['UserID']
Ian S
That looks OK to me.
Is this on a different page to the one you attached?
Having you got <?php session_start(); ?> at the top of the page so that the SESSION call can read the value?
Cheers
Ian
hbibizadeh396670
Its all the same page, but this is a more up to date version
An interesting point, for testing purposes. I edited the sql to have the ids in the database, and it did work. (The add friend button was hidden) but when i try and use the session variables etc... it stops working.
hbibizadeh396670
Any Ideas?
Ian S
Have you added the session_start code at the top of the page?
Cheers
Ian
hbibizadeh396670
Yep, I added the code on line 1
