Remote Parse error
Thread begun 6/04/2012 1:39 pm by paul283230 | Last modified 6/08/2012 11:41 am by Jason Byrnes | 3918 views | 9 replies |
paul283230
Remote Parse error
I would be obliged if someone could help me with the following please.
I have the latest versions of Ecart, Design Extender , and Data Bridge
My site has been working fine no problem I inserted a new menu item, on the local server it is working fine but when i uploaded my files it came back with the following message
Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /????/?????/public_html/webassist/framework/framework.php on line 3
www.bury-governor.com
Tried deleting all the files and uploading new but still get the same problem.
On local server there is no problem?
Just on the remote server.
send a copy of the page and the webassist/framework/framework.php file please, in a zip archive.
paul283230
Jason,
Thank you for getting back to me
error comes up on all pages I have enclosed index and framwork php files
Zip attached As requested
Paul
the index page you sent does not have framework builder applied to it.
i need a copy of the page that has framework builder applied to it.
paul283230
Jason,
I have Just found and solved the problem.
The Problem was CSSMenuWriter , when I constructed the site originally my extensions were independent of each other now they are all together when I edited the templates one came up with one edit button and the other with three edit buttons.
When I deleted CSSMenuWriter off my templates and off the site and inserted a new menu system from a third Party the website was up and running again. Boy was I pleased
It looks like the old single version of CSSMenuWriter is not compatible for editing with the updated version?
Before I updated to the new webassist versions my old ones were the latest versions
Thank You
Paul
hmmm, interesting, i have been able to edit MW Menus using Design Extender without an issue, not sure why that would have caused the error.
paul283230
Jason,
I tried a test on the remote server.
I deleted CssMenuwriter on my templates and the CssMenuWriter Directory then reinserted CssMenuWiter on my templates menus works fine on my localhost server but fails on the remote server in framework.
the only difference i can see is the versions of php I am using 5.3.10 and the remote on the Cpanel is showing 5.2.17
When l delete CssMenuWiter there is no problem on the site with FrameBuilder.
error with CssMenuWiter inserted on website
Test site: new_website/
Paul
please send a copy of all the files involved so i can examine the code.
paul283230
Jason,
Files attached as requested
Paul
