The page isn't redirecting properly
Thread begun 6/01/2012 2:20 pm by james276087 | Last modified 6/06/2012 8:41 am by james276087 | 8581 views | 11 replies |
james276087
Hello,
I try Purchased a garment from my site.
After click SUBMIT ORDER, I'm getting this message
"The page isn't redirecting properly"
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
This problem can sometimes be caused by disabling or refusing to accept
cookies.
Little advice please....
ps. More you know more confused???
please post a link so i can see the problem.
james276087
thank you
checkout_failure.php
on the failure page, change the following code:
if (!empty($_SERVER['HTTPS']) && $_SERVER['HTTPS'] != "off") {
  header("location: http://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI']);
  die();
/*if (!empty($_SERVER['HTTPS']) && $_SERVER['HTTPS'] != "off") {
  die();
james276087
Please tell me where to find that code and change...
thanks for your patient....
in the checkout_failure.php page.
james276087
I went to PAGE SOURCE from Web developer(tools) but getting same message.
Maybe I don't know how to look for that code??
you need to edit the PHP code on that page, you wont see the code in the browsers developer tools, you need to access the page directly to edit the code.
james276087
Why do I have to change the code???
I know it is stupid question, I should just find the page and change the code.
When you have time....
james276087
After I changed the code.....
I got this error message...
I copied few lines of the code so you might see the Line 6..
Parse error: syntax error, unexpected '}' in /hermes/bosweb/web218/b2186/ipw.sanpedro/public_html/checkout_failure.php on line 6
thanks again
die();
require_once('webassist/themes/theme_open.php');
$WAIncludeContent = new WA_Include(__FILE__);
