Drop downs require double click to expand?
Thread begun 6/01/2012 4:42 am by Demetri | Last modified 6/06/2012 8:03 am by Jason Byrnes | 3286 views | 3 replies |
Demetri
Hi
Recently come across an issue where the drop down does not expand on first click, but requires a second click. Is this a compatibility issue with IE, or something that needs to be changed on the drop down?
Using IE 8.0.7601.17514
This is not a problem i have encountered before.
please post a link to a page where I can see the problem to investigate the cause
Demetri
I will have to recreate the page somewhere public first.
In terms of the problem, I don't get it personally, only one user but I don't know if this is due to the later version of IE as I detailed in my post.
it should not be an issue with IE8, I would need to see the problem occur in order to troubleshoot the cause.
