ecart issues
Thread begun 7/31/2009 1:36 pm by elewis93815 | Last modified 8/10/2009 4:11 pm by Eric Mittman | 7757 views | 8 replies |
elewis93815
ecart issues
I would like some direction with a store that we are in the process of building with ecart. This particular store is for clothing merchandise. So we have created the database tables that we can pull "size" and "color" for each T-shirt purchase. My question is in reference to the drop downs for sizes and colors. Right now it is only pulling up the first record in each table e.g., "black" or "small" when we try to add a T-shirt to the cart. I'm not sure if this is an issue with our recordset or the dynamic drop or both. This is our first time creating the drop downs so we are not sure if our direction is correct.
Also, when attempting to create the checkout pages, we have the cart display page opened, we click to open the checkout wizard, it opens and we can change the buttons on the top of the page but none of the buttons on the bottom work, e.g., "help" "get started" etc. We have restarted Dreamweaver in an attempt to shake off any glitches but no luck
Thanks for your help,
Jackie
elewis93815
recordset filtering?
We have created a store with just one product, for now and are having some trouble with the recordset filtering. We are only seeing the first record populating in the cart. e.g. when we purchase a white t shirt in X Large it will populate "small" "maroon' which is the first record in both tables. I think, but not sure, that we should filter our recordset but I'm not sure what type of filter to apply or if this is the direction that should be taken. Any ideas????? Please visit mira_store.php to see what we are talking about.
CraigRBeta Tester
I have only managed a quick look, but it looks as though your 'add to cart' form doesn't have the size and colour lists in it, they are in separate forms called form1 and form 2.
you need to have these lists in your add to cart form, so when you press the add to cart button, it passes the post variables from the form to the code
elewis93815
A little more information please
Thanks CraigR can you give us a little more direction, we've tried a bunch of possibilities and still no luck.
Were you able to combine the forms on the page so that you have only a single form for the add to cart? You can post back here with the page if you are able and I can show you what must be done on the page to combine the two. If you need some assistance with this and cannot post the page here let me know and I will open a support ticket for you so that you can post the files privately.
CraigRBeta Tester
As it stands, on your add to cart page, your size selection list (called parent) is in its own form 'form1' and the color selection list (child) is in its own form 'form2'.
these both need to be contained within the add to cart form, which you have called mira_cart_1_ATC_.
At present, your add to cart form is passing size = "4" and value = "1" to the cart whenever you click the add to cart button.
What it isn't doing is passing the values from the lists, as they are not contained within the form.
elewis93815
Thank you for the feedback
Hello Eric,
We would be interested in opening a ticket and working on this with you. Is there anything you need us to do?
Thank you again for your reply.
I have gone ahead and opened a ticket for you. Please login to WebAssist.com and visit your support history area to update this ticket with your add to cart page and any other info you have. I don't think this should be too difficult to debug when we can see your page, like Craig mentioned it is probably just adjusting these forms that will allow it to work.
We were able to get this resolved in a ticket by combining the forms so that you have only the one add to cart form on the page.
