Problem with "
Thread begun 5/31/2012 8:44 am by J7HNW | Last modified 6/01/2012 9:47 am by Jason Byrnes | 5132 views | 15 replies |
J7HNW
Problem with "
We have universal e mail 4 collecting data from a MySQL database ( in hiddeen fields ) and mailing an HTML e mail to our customer
However if anybody happens to type in " as in 12" x 9" x 3" - it stops the mail from coming through properly
Please see attached. As soon as I take out the " it works fine
How do I work around this please
John
try adding the following code at line 1 of your page;
@session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $k => $v) {
$_POST[$k] = htmlspecialchars($vENT_QUOTES);
this will convert the quotes to HTML entities.
J7HNW
Thanks - but didnt work ?
Hi
I added your code to line one of the Page carrying the UEM4 behaviour and also to the universal_e_mail Quote form in the e mail folder - but no change
Please see attached for my filles ?
Thanks for your help Jason
change:
//$_POST[$k] = htmlspecialchars($v, ENT_QUOTES);
right after i posted, i realized that line was commented and edited my original post, you must have been quick on ready my reply and got the code before i edited it.
J7HNW
Still not working
Hi Jason
Still not working
I now have
@session_start();
if($_SERVER["REQUEST_METHOD"] == "POST") {
foreach($_POST as $k => $v) {
This is on the first line of the 2 pages I attached in the previous post
Regards
John
perhaps try using this code then:
@session_start();
if(
    foreach(
$_POST[$k] = str_replace("\"""&quote;",$v);
J7HNW
Still no ...
Hi Jason
Tried
@session_start();
$_POST[$k] = str_replace("\"", "&quote;",$v);
Still no good. Any more ideas ? Thank you for your swift assistance as always
John
try using the str_replace function in the value of the form elements so that it is already converted before posting. For example:
change:
<input name="quoteref" type="hidden" id="quoteref" value="<?php echo $row_WADAcustomer_quotes['Quote_Ref']; ?>" />
<input name="quoteref" type="hidden" id="quoteref" value="<?php echo str_replace('"''&quot;',$row_WADAcustomer_quotes['Quote_Ref']); ?>" />
J7HNW
Almost there...
Hi Jason
It now reads
12\" x 12\" x 12\"
Almost there - any idea how to remove the \
Rgds
John
use another str_replace function:
<input name="quoteref" type="hidden" id="quoteref" value="<?php echo str_replace('"''&quot;'str_replace('\\''' $row_WADAcustomer_quotes['Quote_Ref'])); ?>" />
