SQL Files
Thread begun 5/30/2012 10:50 pm by bill173836 | Last modified 6/01/2012 7:21 am by Jason Byrnes | 1136 views | 1 replies |
bill173836
SQL Files
I tried using the wizard to set up a store admin and it creates the php files fine but doesn't create any of the database tables even though there is database access. Where can I get the sql files to use to create my tables for all of the options in the wizard? I want to use all the different including the CMS and comments too.
the table should have been created in the testing server mysql database.
the create table statement for the Product Administration application type is:
CREATE TABLE `Products` (
`ProductID` int(12) NOT NULL AUTO_INCREMENT,
`ProductSKU` varchar(50) DEFAULT NULL,
`ProductName` varchar(100) NOT NULL,
`ProductPrice` float(12,2) NOT NULL,
`ProductRetailPrice` float(12,2) DEFAULT NULL,
`ProductShipping` float(12,2) DEFAULT NULL,
`ProductWeight` float(12,2) DEFAULT NULL,
`ProductCartDesc` varchar(250) DEFAULT NULL,
`ProductShortDesc` varchar(1000) DEFAULT NULL,
`ProductLongDesc` text,
`ProductThumb` varchar(100) NOT NULL,
`ProductImage` varchar(100) NOT NULL,
`ProductUpdateDate` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
`ProductStartDate` datetime DEFAULT NULL,
`ProductEndDate` datetime DEFAULT NULL,
`ProductStock` float(12,2) DEFAULT NULL,
`ProductLive` tinyint(1) DEFAULT '0',
`ProductUnlimited` tinyint(1) DEFAULT '1',
`ProductDigital` varchar(250) DEFAULT NULL,
`ProductMaxDownloads` int(12) DEFAULT NULL,
`ProductNonTaxable` int(1) DEFAULT '0',
`ProductTitle` varchar(100) DEFAULT NULL,
`ProductMetaKeywords` varchar(255) DEFAULT NULL,
`ProductMetaDescription` varchar(255) DEFAULT NULL,
PRIMARY KEY (`ProductID`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8
you can find the create table statements for each application in the users configuration folder.
for help finding the configuration folder, see the common installation issues page:
common_installation_issues.php
once in the configuration folder, go to Shared/WebAssist/DataAssist/XML/Schema, there is an XML file for each application type.
