download counter
Thread begun 5/30/2012 2:50 pm by rayne202093 | Last modified 8/08/2012 2:09 pm by Jason Byrnes | 7279 views | 16 replies |
rayne202093
download counter
I want to use digital file pro to handle the downloading of one file to customers who log in to see the link. I can do all the log in code and get the customer to the download page, but had a question about how the download counter works.
Does the download counter (update download count in database) keep count of how many times an individual person (identified through a session variable) downloaded the file or is it just a global count of how many times the file has been downloaded?
If it doesn't keep a count of how many times a single person downloads the file, is it possible to write the session variable of the person into the download counter table every time he downloads the file?
Thanks.
--rayne
it can do either, keep a global count, or count for a specific person, it all depends on how you set the Key Column section.
the Key Column section sets how the download count will determine what to update.
to update a download count column in the users table, set the key column to the User ID and for the value, use the Users session variable.
rayne202093
I have setup a form that a user fills out with a serial number and then submits. His serial number is checked to make sure it has not expired and if it has not a "download (submit) button" is displayed. The user then clicks the download button and the file is downloaded successfully. All that works great. However, no entry is written in the download counter table.
In the "configure file download settings" dialog box, I set up the download counter options as:
checked: update download count in database
connection: the correct connection
table: the table name to hold the count information (which the dialog box found)
key column: keycolval field
key column value: <?php echo $row_Recordset1['serialno']; ?>
count column: countcol field
The table exists, the fields exist, the file is downloaded successfully, but no record is entered into the table when the download button is clicked. No error is generated. Did I miss a step in setting the download counter up?
Are there any online instructions beside those found here: digital_file_pro.html?
Thanks.
--rayne
the download counter does not create a new entry in the database, it updates an entry in the database.
since you are using a recordset value for the key column value, make sure the code for the recordset is before the code for the download.
also, if the recordset has any filters, those will need to be included in the form submit.
If you need further details, send a copy of your page in a zip archive so I can see the entire page code.
rayne202093
If the download counter doesn`t create an entry, how does it keep track of new people that download the file? It doesn`t write the initial entry of a download and then increment it if that person downloads the file again?
I have attached a copy of the page.
Thanks for the help.
--rayne
the download count column of your table should have a default value of 0, so that whenever a new record is initially created, the count is set to 0.
rayne202093
I am sorry to be dense, but I need to keep a count of how many times a person downloads a file. So how does the download counter do that if it doesn't write the record in the table the first time someone downloads the file?
--rayne
in the database, you need to set the download count column to use a numeric data type, and you need to set the download count column to have a default value of 0.
when the user downloads the file, the download behavior will be able to increment the 0 value to 1 and so on. But only if there is a default value of 0. If there is no value, the increment cannot happen because it will be set to NULL, math cannot be performed on a NULL Value.
rayne202093
OK, so everyone that might ever download the file has to already be in the table with their count set to zero for the download counter to work? The script only looks up the record to increment it?
--rayne
yes, that is correct.
