MySQL Error#: 1064 You have an error in your SQL syntax; check the manual that corr
Thread begun 7/31/2009 11:49 am by mick106153 | Last modified 8/04/2009 2:38 pm by Jimmy Wu | 30049 views | 5 replies |
mick106153
Powerstore V2
Any page that is bound to "Recordset (WADAProducts)" gives the error:
" MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2"
when I click the tab next to "Recordset (WADAProducts)" in the bindings tab.
In "Server Behaviors" opening "Recordset (WADAProducts)" shows the following in "SQL":
"SELECT * , (ProductStock - (SELECT Coalesce(Sum(DetailQuantity),0)
FROM orderdetails INNER JOIN orders ON OrderID = DetailOrderID
WHERE DetailProductID = ProductID AND OrderDate > ProductUpdateDate))*ProductLive AS NumLeft FROM products WHERE ProductID = ParamProductID OR ( -1= ParamProductID2 AND ProductID= ParamSessionProductID)"
test shows no data and my connection is fine.
Mick
PS. I did try finding an answer in your forums and found a few references to a similar problem but no answer.
In one case the person posting resolved the issue on their own without explaining how or why.
I think that all resolutions should be fully fleshed out so as to make it easier for us to troubleshoot on our own without having to take up your valuable time and if one of you were to offer a synopsis of the process to the resolution, dumb it down if you will, I know it would help me and probably others as well.
Jimmy Wu
If what you are trying to accomplish is to bind a column to the page, you can use this syntax:
<?php echo $row_WADAProducts["ProductLongDesc"]; ?>
Replace "ProductLongDesc" with the column name you want.
We will continue looking into this issue and hopefully we will be able to find a fix. The store should work even with this issue.
mick106153
I don't know what I'm trying to do.
I spend time poking around in the guts of the underlying technology in hopes of furthering my understanding of php and MySQL.
My previous post was in reference to the fact that what I described there, occurs.
And that that may be an incipient cause of some problem of which I may not yet be aware.
If it is not and there is not a resultant cascade of undesirable consequences as you seem to indicate, than I should just ignore it?
Your answer, though appreciated, confuses me as much as the other posts I've read in an attempt to find an answer to this problem.
Could you please present, or point me to, a "roadmap" that illustrates the sequence of events generally necessary to achieve what you've described as a fix.
Mick
Jimmy Wu
The SQL statement works and does what it should do, but sometimes if the SQL is more complicated, Dreamweaver has trouble reading it. The fix would involve changing the SQL query to something that accomplishes the same task, but can be read by Dreamweaver. This would involve getting a new release of PowerStore out to the users.
As for my response, I wasn't sure what you were attempting to accomplish when you were double clicking on that recordset, so I offered up the solution to a common issue of displaying the value of the recordset column on the page.
The functionality of the store should be fine, however, so if you can, just work around the issue.
mick106153
Meant no disrespect
If my response was disrespectful, it wasn't meant to be.
I do appreciate your response. I just get a little frustrated because your (collectivel) skill level is so far beyond my own that you often talk way over my head.
So to sum.
The problem is not with php, MySQL, WebAssist et al or me. It's with Dreamweaver and can therefor be ignored.
Is that correct?
If so, than where do I see what is contained in i.e. Recordset (WADAProducts) if not in the bindings panel since there an error is thrown when trying to view it? If it is even necessary to do so.
As you can probably tell, I'm still quite confused about how all this goes together.
Mick
Jimmy Wu
Yes, you don't have to worry about that error.
So the code I gave you in the first response was to display the value of a column value of a record in that recordset.
That particular recordset will basically contain information about products that you have added to your PowerStore.
