Making the add to cart button work
Thread begun 5/30/2012 6:34 am by tyler815351411 | Last modified 5/30/2012 4:04 pm by tyler815351411 | 3743 views | 2 replies |
tyler815351411
I have used data bridge to create some a standard result and detail page for a small shop website I am building. Data bridge has created the pages and inserted the add to cart buttons. I have used ecart 5 to setup the cart page and all the other pages.
But what do I need to do in order to get the add to cart button to work. Before using data bridge I wouold just insert an add to cart button where I wanted on the page, but I get an error saying that there is already a form.
I am assuming that I need to adjust the add to cart button that data bridge has created so that it adds the item to the cart and then re-directs users to the shopping cart page I created using ecart.
Please can some help, I tried all day looking through your website to find a tuturial for this but could not find one.
See attached results page
Kind Regards
Brian
When creating the Detail page, you should deselect the option to include the delete button if it will be used as a public add to cart page.
The add to cart button that is added, is really just a place holder.
you should delete the following code from the detail page:
<form class="DetailsPage Cool_Default" id="Results_Cool_Default" method="post"  action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<input type="submit" value="Add To Cart" class="formButton Cool" id="Cool" name="Cool" />
</form>
then add the eCart add to cart button behavior.
tyler815351411
Many thanks all sorted
