Delete Button Not Re-Routing
Thread begun 5/30/2012 3:52 am by salaroche | Last modified 5/30/2012 2:07 pm by Jason Byrnes | 6062 views | 10 replies |
salaroche
Hi:
Within the WADA Search sequence, the Delete page is deleting records, but it's not re-routing the page to the Results page. Why would that be?
I'm testing the Website in two different servers, in one of them the Delete page works well, but not in the other. In the latter it just doesn't find the Results page. If this is a problem with server compatibility, how do I solve it?
Is WebAssist's code compatible with PHP 5.2.17?
Attached you will find the Delete page in question.
Thank you for your attention
most likely a php error is occurring that is preventing the redirect.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
salaroche
Jason:
Thank you for your reply.
In entered the code you suggested and I got the following error message:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home1/djibaca1/public_html/oxad/OxAdDelete.php:5) in /home1/djibaca1/public_html/oxad/OxAdDelete.php on line 68
Warning: Cannot modify header information - headers already sent by (output started at /home1/djibaca1/public_html/oxad/OxAdDelete.php:5) in /home1/djibaca1/public_html/oxad/OxAdDelete.php on line 76
see the following thread for troubleshooting and fixing that error:
showthread.php?t=19285
salaroche
Jason:
Thanks again. I tried deleting some text lines on line 69 and line 70, which seemed to be the closest possible trouble makers according to the example, but I only got error reports for other code lines.
Any suggestions?
the error is reporting the problem at line 5:
it is blank space between php code blocks near line 5.
salaroche
I found two blank spaces at lines 14 and 16. I got rid of those spaces, but I still get errors...
salaroche
Now I'm not even getting the same error messages. I'm getting this:
The page you are looking for could not be found.
Try searching for it in the address bar above.
the error is not saying anything about line 14 or 16.
read this part of the error:
it says the problem is around line 5.
probably line 4.
it could be a blank space at the end of the closing php tag:
or a blank line between php tags:
<?php"
salaroche
Jason:
Sorry to say that I haven't been able to find any blank spaces or lines between php code blocks or anywhere else near line 5. The page still doesn't reroute. Unfortunately I have to go cause they're closing this place. After all, this is Djibouti, in East Africa.
If there's anything you can do about this, please do it. It will be highly appreciated. I'll check the forum again tomorrow morning my time
Thanks for your attention
