Missing Multiple Items from Map
Thread begun 5/29/2012 9:55 pm by dwebb40212 | Last modified 6/01/2012 8:04 am by Massimo | 18886 views | 7 replies |
dwebb40212
I cannot seem to get the entire recordset to display correctly in my Google Map. I have noted that if I delete the existing items which are being displayed that a limited number of alternative records are being displayed. The current record set should display 97 different locations. The link to the current map is as follows:-
sydney_city_google_map.asp
many of the addresses you are using are not specific enough for google to find using the google geocoder.
for example:
Level 1 - 47 Murray Street, Pyrmont, Sydney, NSW, 2009, Australia
If i visit maps.google.com, google cannot find this address.
another address that wont work is:
Suite 118/243 Pyrmont Street, Pyrmont, Sydney, NSW, 2009, Australia
The google geocoder does not understand suite numbers.
or this:
Lower Level - Star City Casino, Pyrmont, Sydney, NSW, 2009, Australia
does not offer a street number.
These may be addresses a human would understand, but the google geocoding service does not.
however, this address:
205 Harris Street, Pyrmont, Sydney, NSW, 2009, Australia
uses a properly formatted street number, so google can find it.
dwebb40212
Hi Jason
Thanks for your response. I do take your point about the incorrectly formatted addresses. I have subsequently amended and tested an address list which all individually display correctly in Google Maps when entering manually.
However I am still experiencing the same problem when trying to create the map from a recordset. Only ten markers are being displayed. I noted that when I re-sort the recordset order that 10 different markers are displayed. I am therefore at a lose as to why only 10 markers are showing and not the full recordset.
The new testing page is temp_google_map.asp
Thanks for any assistance you may be able to provide.
Massimo
Same problem
I want take from db some address and display pin on map.
For any address I have only city: ex.
Napoli, Italia
Nuoro, Italia
Roma, Italia
and so on.
But I take only first address
why?
example page are: location.php
@Massimo - yours is a different problem. in the wagmp_map_1.php file find each occurrence of the following string:
'google_javascript/images/
and change it to:
'webassist/google_javascript/images/
@dwebb40212 - What version of Pro Maps for google are you using? Make sure you are using the latest version 1.0.7 available from the download center
Massimo
Now Work, but I'm using design extender 1.0.6 so I had unistalled Pro Maps. What should I do?
thanks
@Massimo - there will be an update to design extender to correct the issue you are having released soon
Massimo
Ok thanks! I wait for it. Ciao
