selection changes to first in list
Thread begun 5/29/2012 12:19 pm by Sweens | Last modified 6/05/2012 12:39 pm by Jason Byrnes | 6207 views | 13 replies |
Sweens
Hi
Attached txt file is the code from a page that has a dynamic dropdown. The dynamic bit works - but as soon as you move the mouse to go and click the 'add' button, the selection reverts to the first item in the list.
I see there's a mouseover bit of code, but can't see its relevance to the problem, as the selection changes well before you get to the add button (button done wit button styler)
If you make a selection and tab to the add button and press enter, the record inserts properly.
Any ideas?
BTW - I think it's a great shame that this extension is being discontinued - I hope that webassist will create their own jquery version to help us non-tecchies!
Cheers
Chris
The populate list from array behavior should be set to the OnChange event of the parent list.
you have it set to the onMouse over event of the p tag that contains the submit button, it should not be on the submit button p tag.
Sweens
Thanks Jason - if only I knew how to change it! I've run the behaviour again several times and with varying degrees of failure!
you need to remove the onMouse over event code:
change:
<p onmouseover="WA_FilterAndPopulateSubList(rsPostList_WAJA,MM_findObj('CtteeID'),MM_findObj('PostID'),0,0,false,': ')">
<p>
Sweens
Hi Jason
Done that - but now the dependent dropdown doesn't work.
Cheers
Chris
the populate list from array behavior needs to be added to the on change event of the parent list.
Sweens
Hi Jason
Tried that - now I get the dynamic dropdown (which I did before), but when I select one of the list items, nothing happens - it stays as the first in the list.
Cheers
Chris
please send a link where i can see the problem, and send a copy of the page in a zip archive so I can examine the code.
Sweens
Hi Jason
Thanks - the original message contains the source code; I'm afraid I can't provide a link, as it's in a restricted area.
Cheers
Chris
but in the code from the original post, you did not have the Populate List From array behavior applied to the onchange event of parent select list.
you had it applied to the onmouse over event of a p tag.
I told you to remove it from the p tag and add it to the onchange event of the parent select list.
If this is not working, then I need to see the Current state of the code. the original file doesn't do any good since it does not accurately reflect the code that is running in the page now....
compress the current version of the file to a zip archive please....
