Update single record - bindings
Thread begun 5/25/2012 9:10 pm by enquiry272230 | Last modified 5/26/2012 1:37 am by Ian S | 801 views | 1 replies |
enquiry272230
HI,
I have been using CS5.5 and Data Assist.
Have just started trying to use CS 6 and data bridge instead.
I have version 1.02
OS is Mac OSX 10.7.4
Tried to edit an update record behavior created initially with Data Assist, by double clicking the behavior in the behaviors panel. The dialog opens OK, but in "Bindings" an unusual thing happens:
In the bindings panel, I select a column and click the value lightning bolt.
Multiple "Select a Server Entity" dialog boxes open, and continue to open as long as my mouse hovers over the lightning bolt.
I then have to "Cancel" the multiple dialogs.
Not sure if other behaviors have the same issue
Not willing to risk using Data Bridge until it's more stable, going back to using CS5.5 and Data Assist in the meantime.
Ian S
This is a known bug experienced by Mac users in CS6.
WA are working on a fix and this should be out next week according to Jason.
Cheers
Ian
