Default value for registration
Thread begun 5/25/2012 2:53 pm by h150477 | Last modified 5/29/2012 6:46 am by Jason Byrnes | 1461 views | 2 replies |
h150477
Registration on my site is done by a person other than the one being registered. Eleven people all belonging to different clubs are registered as editors for their club.
They are only allowed to register new members for their club. Each registered person has a club_index field that points to the index field in the clubs table.
So the editor logs in and goes to the registration page and enters the registration information for his new member.
Using the standard registration page, with minor modifications to use a menu for the user level, I can get the page to work - but with no club_index.
A new user can only be registered to the club to which the editor belongs, so a session variable supplies the club_index shared by both the editor and the new user.
This club_index does not change, and as far as I can see, it should not need to be validated, as it is provided by the system.
So how do I get this session variable's value transferred into the club_index field of the newly registered user?
On a none SA form, I would usually set the value of that field to a hidden field on the form, and the session variable would be bound to the club_id field in the insert record behaviour.
However, this does not seem to work in SA or I am doing it wrongly, as all the fields on the form change from yellow to green.
When I click the submit button, I get the "Invalid information, please check your entries and try again."
All entries are correct as no other validation errors are shown, yet this error still persists, so it must be a problem with the hidden field. Gets a bit wearing after a while.
I could just insert the user without a club_id and then do an automatic update it on the next page, but that seems to defeat the object.
Just what is the purpose of the hidden field in SA? How can one use it? There is no documentation for this item anywhere that I can find, and it obviously needs some.
All suggestions welcome.
h150477
Still no answers, but there is a solution to the problem in part - after some 12 hours plaaying with SA.
To pass a single value using the standard SA registration form, create a stock dreamweaver recordset containing a single value.
Like select club_index, club_name from clubs where clubsession = 2
Then populate a menu with the single value within the recordset.
Bind the insert record field to the recordset field and you have done.
It looks like a drop down list but it only contains one value. Must be a better way but it will have to do for the moment.
If you need to register someone from the admin side, all that is is needed is copy the file and widen the scope of the recordset to include more options in the copy.
Still don't know how the SA hidden field is used. Should just be able to bind the session variable to it but ......?
  Still no answers,
You post was made late Friday evening, WE are available Monday - Friday 9am to 5pm PST, except for major US holidays. Monday was the Memorial Day Holiday.
the default value should be set directly in the Database.
In the database, select the column and set the default value to whatever you like. the attached screenshot is an example of using PHPMyAdmin to set the default value of the UserEmail Verified column to 0.
By setting the default value in the database, you don't need to bind that column to anything in the insert record behavior.
