Product Categories is alphabetical order
Hello,
Product Categories is alphabetical order BUT can I put them the way I want it????
thanks for reading.....
Hello,
your question is a little confusing, power store is designed to show the categories in alphabetical order. You could change it to show in the order you create them by editing the recordsets in the pages of the webassist/plugins/side_menu and webassist/plugins/main_menu/menu.php pages
you would need to change the ORDER BY Clause to use the ID column instead of category name, but this is not a supported modification.
thank you and I better not do anything and very happy with it..
You have nice and safe long weekend.
Product Categories is alphabetical order A to Z.
My product number is getting greater so Is there I could changed to Z to A (reverse it??)
thank you for reading
So New product will show on the top.
thanks for your time,,,
you would need to edit the recordset code in the webassist/plugins/side_menu and webassist/plugins/main_menu/menu.php pages to use ORDER BY ProductName DESC
