Show category hierarchy by product ID.
Thread begun 5/25/2012 7:15 am by CraigR | Last modified 5/29/2012 8:34 am by Jason Byrnes | 3160 views | 5 replies |
CraigRBeta Tester
I have been asked to show all of the categories to which a product belongs. (PS3 database)
Querying the ps3_productcategories table, it is easy to establish which categories a product belongs to, but I would also like to see the hierarchy.
So, for example, Item number 1 may belong to 6 categories, two of which are parent categories, and the others are sub categories.
Hierarchical view may look something like this…
Category 1->Category 2->Category 3
Category 4 ->Category 5
Category 4 ->Category 6
In this instance,
Categories 1 and 4 are parent categories
Categories 5 and 6 are subordinate to Category 4
Category 3 is subordinate to Category 2 which is subordinate to category 1.
I’m not necessarily looking for a definitive answer, just some idea as to a method of approach.
the hierarchy is set by the CategoryParent column of the ps3_categories
you would need to use a join query to to return the CategoryParent parent and create the hierarchy from that column.
CraigRBeta Tester
sorry, I can't quite get it
here's what i have done..
i am checking for 3 levels of hierarchy, (if there's a way to check for n levels, i would love to know)
knowing the product ID, 35 in this instance i am joining the products table, the productcategories table and the categories table, (3 times) in each case joining each instance of the categories table on Category Parent to CategoryID of the next instance.
I get a result, but I get a duplicate row where the 3 level hierarchy is displayed, but also the last 2 levels are also displayed on a different row.
Am I missing the point ?
SELECT ps3_products.ProductID, ps3_categories_2.CategoryParent AS Cat2Parent, ps3_categories_2.CategoryID AS Cat2ID, ps3_categories_2.CategoryName AS Cat2Name, ps3_categories_1.CategoryParent AS Cat1Parent, ps3_categories_1.CategoryID AS Cat1ID, ps3_categories_1.CategoryName AS Cat1Name, ps3_categories.CategoryParent AS CatParent, ps3_categories.CategoryID AS CatID, ps3_categories.CategoryName AS CatName
FROM ((ps3_products INNER JOIN (ps3_categories INNER JOIN ps3_productcategories ON ps3_categories.CategoryID = ps3_productcategories.CategoryID) ON ps3_products.ProductID = ps3_productcategories.ProductID) INNER JOIN ps3_categories AS ps3_categories_1 ON ps3_categories.CategoryParent = ps3_categories_1.CategoryID) LEFT JOIN ps3_categories AS ps3_categories_2 ON ps3_categories_1.CategoryParent = ps3_categories_2.CategoryID
WHERE (((ps3_products.ProductID)=35));
yeah, your missing it a bit.
there is no need to use the multiple joins, not using multiple loins is how you do n levels.
use a group by clause on the CategoryParent
and create the hierarchy by looping through the records in the recordset.
you may need to order by the CategoryParent as well, and add logic that will save the CategoryParent in a variable, then the next time through compare the current record CategoryParent to the one in the variable and only write it if it is different.
If you need us to help you create this, I would suggest signing up for a premiere support appointment.
CraigRBeta Tester
Ok, (I think) I get it now.
What I have done is to take the getaccordion function which generates the vertical menu as a guide, and use this logic, removing any unecessary functionality and also filtering by the product id.
Seems to give me what I need, thanks for the advice.
Glad to hear it is working.
