Guide or Recipe for DataAssist working with Joins?
Thread begun 5/24/2012 1:38 pm by Justin@AdventDesign | Last modified 6/05/2012 9:15 am by Jason Byrnes | 2726 views | 6 replies |
Justin@AdventDesign
Need to have my detail page suggest other products the viewer would 'like', unique to each product. I plan to have a secondary table with the primaryID (the current detailed product) and a secondaryID (multiple products listed). I know on the detail page I'll need to do a join and pull a second recordset based upon those fields.
I'm just not sure how to do the dataassist insert and update page so that the client can list part numbers for the 'like' items and have it write/update both the primary product record and multiple 'like' records for the secondary table.
Is there a Recipe or some type of guide somewhere that would walk me through that setup process?
no, there is not a tutorial for this.
from the product results page, create a link to the page you set up to insert or update the Like products.
the link should contain a URL parameter that passes the main product ID:
for example.
productslikeInsert.phpid=33
add a hidden form element will capture the URL variable value.
create a repeat region that shows products in the database and a check box next to then that contain the product ID's.
In the multiple insert or multiple update behaviors, set the mainProduct column to use the hidden form element, and set the like product column to use the checkboxes.
Justin@AdventDesign
Hmm... I didn't realize there was a multiple insert/multiple update behavior. That all sounds quite simple enough. Bet I could use that too on the results page for a multiple delete I'd like to employ. Thanks.
Justin@AdventDesign
Repeated Error When Applying Multiple Updates
I've created a simple page that pulls all records from my related items table (tbLikeItems containing id(key), ParentNo, ChildNo. I insert the data from the ChildNo as the input default value. So far everything works fine. It selects the table with the proper elements using a URL Parameter and repeats the form input blanks just fine.
However, when I add the Multiple Updates behavior and run the page, I get "Parse error: syntax error, unexpected ';' in /Applications/XAMPP/xamppfiles/htdocs/beta/PSDesigns/sitecontrol/tbProducts_RelatedInsert.php on line 64"
I've attached the page.
Justin@AdventDesign
Never Mind! Idiot operator error on my part. Have to click through to the second panel when setting up the Multiple Update. Duh!!!
Justin@AdventDesign
Just a little more help.
I've got the admin pages working great for creating and editing the related items table, but I'm struggling with the table join for the front end.
We have an item detail page that needs to display related products. There are two tables to deal with, tbProducts and tbLikeItems. Taking the URL Parameter 'partno' , the MySQL statement would need to select all items from tbProducts where tbLikeItems.ParentNo = the URL Parameter 'partno', and then select various columns from tbProducts where tbLikeItems.ChildNo = tbProducts.partno .
I know this involves a table join, but the part that confuses me is that tbProducts has to be used on both ends of the query, as the identification for primary id (partno) and then returning info from tbProducts that match in the tbLikeItems.
Can anyone give me a rough framework for the query statement?
Tables are as follows:
tbProducts
id
title
partno (product part number)
various other columns of info...
tbLikeItems
id
ParentNo (product part number of the primary item)
ChildNo (product part numbers of the related items to be shown)
The query would look similar to this:
SELECT tbProducts.*, tbLikeItems.*
FROM tbProducts
INNER JOIN tbLikeItems
ON tbProducts.partno = tbLikeItems.ParentNo
WHERE tbLikeItems.ParentNo = parampartno
variables:
type: integer
default value: -1
runtime value: $_GET['partno']
