Please help with datasearch
Thread begun 5/24/2012 4:54 am by info364504 | Last modified 5/24/2012 9:54 am by Ian S | 2550 views | 5 replies |
info364504
Hi, I have created a search by keywords facility.
The problem is it searches by any of the entered words instead of b all of them i.e:
if I search for houses in London, it will return results for houses and esults for all types of properties in London.
Here's my code:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: buscar_palabras_RS;
//Searchpage: buscaPalabras.php;
//Form: form1;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr0 = array("regimen", "localidad", "isla", "tipopropiedad", "zona", "habitaciones", "estado", "metros", "descripcion", "precio", "precio_oferta");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr0,"".((isset($_POST["buscarField"]))?$_POST["buscarField"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_buscador_palabras"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_buscador_palabras"]) && $_SESSION["WADbSearch1_buscador_palabras"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_buscador_palabras"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_buscar_palabras_RS = 10;
$pageNum_buscar_palabras_RS = 0;
if (isset($_GET['pageNum_buscar_palabras_RS'])) {
$pageNum_buscar_palabras_RS = $_GET['pageNum_buscar_palabras_RS'];
$startRow_buscar_palabras_RS = $pageNum_buscar_palabras_RS * $maxRows_buscar_palabras_RS;
mysql_select_db($database_MySQLconnect, $MySQLconnect);
$query_buscar_palabras_RS = "SELECT * FROM t_propiedades";
setQueryBuilderSource($query_buscar_palabras_RS,$WADbSearch1,false);
$query_limit_buscar_palabras_RS = sprintf("%s LIMIT %d, %d", $query_buscar_palabras_RS, $startRow_buscar_palabras_RS, $maxRows_buscar_palabras_RS);
$buscar_palabras_RS = mysql_query($query_limit_buscar_palabras_RS, $MySQLconnect) or die(mysql_error());
$row_buscar_palabras_RS = mysql_fetch_assoc($buscar_palabras_RS);
if (isset($_GET['totalRows_buscar_palabras_RS'])) {
$totalRows_buscar_palabras_RS = $_GET['totalRows_buscar_palabras_RS'];
} else {
$all_buscar_palabras_RS = mysql_query($query_buscar_palabras_RS);
$totalRows_buscar_palabras_RS = mysql_num_rows($all_buscar_palabras_RS);
$totalPages_buscar_palabras_RS = ceil($totalRows_buscar_palabras_RS/$maxRows_buscar_palabras_RS)-1;
Thanks for your help
Ian S
It looks like you have defined a space as both the AND and OR operator for your keywords.
If you set your OR operator to space then
Houses in London
Maybe try changing your OR operator to a comma or something like that so that only the AND operator is a space.
Cheers
Ian
info364504
Thanks Ian, but where do I do that?
Ian S
Its in the DA Search GUI....
You will see the Keyword AND and Keyword OR settings.
Basically it sounds like you want to have the AND operator as a space and maybe the OR separator as a comma (or something else).
Cheers
Ian
info364504
Thanks a lot...that worked fine.
Ian S
Great stuff! No worries :-)
