Help with Security Assist and Framework
Thread begun 5/23/2012 8:16 am by danny405167 | Last modified 5/23/2012 11:41 am by danny405167 | 1065 views | 1 replies |
danny405167
Can Framework be used to include a login page into a page that has Ecart code? For example I have a product page that has add to cart buttons. I am using Framework to include my login page whenever someone wants to login from the products page. The login form pops up in a modal window. When I try to login from the products page I get the following error:
Warning: Cannot modify header information - headers already sent by (output started at E:\vhosts\webTest\store\rings.php:5) in E:\vhosts\webTest\WA_SecurityAssist\Helper_PHP.php on line 38
If I loging from the index page I get I success login. I click on the link to pop up my modal window and I get redirected to my success page.
I was looking for a solution to solve my problem and the only ones I found referred to blank lines on the Helper.php. I deleted all the blank lines and I still was not able to login from the product page.
This is what line 38 has: header("Location: ".$WA_Auth_Parameter["successRedirect"]);
By the way I am NOT using the DYNAMIC plug in framework.
danny405167
I solve the problem. All of my code got corrupted when I was messing with the login page. I had to redo my product page and now it is working fine. Besides deleting extra blank spaces that can cause errors, it is best to save a back up of your working files so that you don't have to redo the same page. Just my two cents.
I notice that when using more than one webassist extension, sometimes the code tends to get all over the place. This causes major headaches when trying to figure out what happened to a working page.
Thankfully that this forum exist where one can find solutions and tips.
