two languages powercms
Thread begun 5/23/2012 6:05 am by Stuward | Last modified 2/03/2014 12:15 am by Jonas | 4724 views | 10 replies |
Stuward
I have read this forum but still have a question.
For the client I have a regular website in two languages. It contains a news-section database with powercms. I have read that making two seprate my_sql databases works for the best and that you can host them to a different (sub)domain.
But I like to keep both languages on one the same domain and ftp. Now I thought about using just two different folders (one per language) and both homepages in the hom directory
../ENG
../CH
How can i accomplish this?
i have bought the Supersuite
Regards, Stuward
you will need to create 2 separate dreamweaver sites, one that works on the /ENG section of the site. and the other to work on the /CH.
this will allow you to create 2 separate CMS Systems on for each language.
Stuward
Thanks Jason, I will explore this way of working...
Stuward
Jason, one question:
i created both databases and seprate dreamwaever sites and they work ok. But how do I manage to trigger the right database per language?
CraigRBeta Tester
are multiple sites really necessary ?
I am currently working on a site in 3 languages with the text content maintained using powercms builder
I do not have separate sites, i have the language set using a session variable and a PHP case statement which inserts the appropriate language content based on the session variable. All of the content is managed within a single instance of power cms for example for the home page, i have sections called content-english, content-dutch and content-greek. Seems to work well.
If you are interested i can post some code
Stuward
Hi Graig,
Yes I am interested in your solution. The most important is that it works appropriately.
It would be great if you shared your code if you like!
Stuward
CraigRBeta Tester
Basically, I have a form at the top of each page, with flag icons, which, when submitted, set a session value to the chosen language.
Then I have a block of php code to set the menu and content accordingly.
eg Menu
<div id="topNavigation">
<?php switch ($_SESSION['language']) {
case 'english': //use the english
require_once("CSSMenuWriter/cssmw0/menu.php");
break;
case 'greek': //use the greek
require_once("CSSMenuWriter/cssmw0/greek/menu.php");
break;
case 'dutch': //use the dutch
require_once("CSSMenuWriter/cssmw0/dutch/menu.php");
break;
default: //use the english
</div>
then something similar for the content areas..
<div id="content">
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home Page', 'content_english');
break;
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home Page', 'content_greek');
break;
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Home Page', 'content_dutch');
break;
</div>
All content is managed by a single CMS.
Don;t know if this approach suits your needs but it works well here.
The site is still very much under development, but here s a link to the home page...
eleanamansion.forthwebsolutions.com
Stuward
Thanks Graig, this is a great and very simple solution. I will use it!
Since I am a dutchman, just one remark with your translation at the menu of eleanamansion.forthwebsolutions.com
Lokaliteit > "Locatie"
Rond Lesvos > "Omgeving Lesbos"
Contacteer Ons > "Neem contact op" (or just: "Contact")
Thank you very much!
Stuward
CraigRBeta Tester
Ok, thanks for that, the original translations were done by a Greek man and passed to me, so I have updated accordingly.
Stuward
Ok Graig, I have send a PM to you...
