Login Form (security assist) Not Working
Thread begun 5/22/2012 1:16 pm by ruth265305 | Last modified 5/24/2012 4:06 pm by ruth265305 | 4890 views | 6 replies |
ruth265305
I created a registration form; forgot password form; userupdate form; and logout form ... all of which work perfectly.
The login form is not working ... I've double-checked the database fields, the username and password and can't seem to find the problem, please help! I'm using the latest Data Bridge extension; Dreamweaver CS5.5; and Windows 7.
A link to the page in development:
login.php
Thanks! I'm on a deadline and this has me stumped.
Ruth
please send a copy of the registration, login and Members-Home.php pages in a zip archive so i can look at the code.
ruth265305
Files Requested for: Login Form (security assist) Not Working
Hi Jason:
thank you for your assistance! The files are attached in a zip file.
the problem is on the Members-Home.php page.
you have a mix of Security assist And Dreamweaver User Authentication.
The Dreamweaver User Authentication. is causing the login to fail.
delete the code from line 7 - 79:
//initialize the session
if (!isset($_SESSION)) {
session_start();
// ** Logout the current user. **
$logoutAction $_SERVER['PHP_SELF']."?doLogout=true";
if ((isset(
$_SERVER['QUERY_STRING'])) && ($_SERVER['QUERY_STRING'] != "")){
$logoutAction .="&"htmlentities($_SERVER['QUERY_STRING']);
if ((isset(
$_GET['doLogout'])) &&($_GET['doLogout']=="true")){
//to fully log out a visitor we need to clear the session varialbles
$_SESSION['MM_Username'] = NULL;
$_SESSION['MM_UserGroup'] = NULL;
$_SESSION['PrevUrl'] = NULL;
  unset(
$_SESSION['MM_Username']);
  unset(
$_SESSION['MM_UserGroup']);
  unset(
$_SESSION['PrevUrl']);
$logoutGoTo "../index.php";
  if (
$logoutGoTo) {
header("Location: $logoutGoTo");
    exit;
session_start();
$MM_authorizedUsers "";
$MM_donotCheckaccess "true";
// *** Restrict Access To Page: Grant or deny access to this page
function isAuthorized($strUsers$strGroups$UserName$UserGroup) {
// For security, start by assuming the visitor is NOT authorized.
$isValid False
// When a visitor has logged into this site, the Session variable MM_Username set equal to their username.
  // Therefore, we know that a user is NOT logged in if that Session variable is blank.
if (!empty($UserName)) {
// Besides being logged in, you may restrict access to only certain users based on an ID established when they login.
    // Parse the strings into arrays.
$arrUsers Explode(","$strUsers);
$arrGroups Explode(","$strGroups);
    if (
in_array($UserName$arrUsers)) {
$isValid true
// Or, you may restrict access to only certain users based on their username.
if (in_array($UserGroup$arrGroups)) {
$isValid true
    if ((
$strUsers == "") && true) {
$isValid true
  return
$isValid
$MM_restrictGoTo "../login.php";
if (!((isset(
$_SESSION['MM_Username'])) && (isAuthorized("",$MM_authorizedUsers$_SESSION['MM_Username'], $_SESSION['MM_UserGroup'])))) {
$MM_qsChar "?";
$MM_referrer $_SERVER['PHP_SELF'];
  if (
strpos($MM_restrictGoTo"?")) $MM_qsChar "&";
  if (isset(
$_SERVER['QUERY_STRING']) && strlen($_SERVER['QUERY_STRING']) > 0
$MM_referrer .= "?" $_SERVER['QUERY_STRING'];
$MM_restrictGoTo $MM_restrictGoTo$MM_qsChar "accesscheck=" urlencode($MM_referrer);
header("Location: "$MM_restrictGoTo);
  exit;
and change the logout link to point to the Security assist logout page:
<a href="../logout.php">Logout</a>
ruth265305
++ Add'l Help, still not working ++ Login Form (security assist) Not Working
Hi Jason,
I followed your instructions, uploaded the new file, and the login page still just sits there. I'll attach my new code. (revised page attached).
What did I do wrong?
you're login link no longer works. Where can i test the login?
ruth265305
changed files
Hi Jason,
While I was waiting for a reply. I started all over again using the assumption that the Members-Home.php page was the problem and that I had dualing authentications.
I have redone all of the pages and am just now testing ... I was just about to post a message that I THINK it might be solved... I'll post again when things are working so we can close the thread. Thanks again so much for your help today.
