P tag
Thread begun 5/22/2012 1:05 pm by nickj | Last modified 6/12/2012 12:33 pm by Jason Byrnes | 4322 views | 7 replies |
nickj
P tag
The kfm editor surrounds the output with paragraph tags which is not always desirable. Also the paste board (text area) is always white which discourages the use of white text which we sometimes need.
So two questions:
1. is there a way to have the html, produced by the editor not surrounded with a paragraph tag?
2. Is there a way to change the background color if the editors text window to another color? Perhaps by passing a color code in a session variable.
1) in the HTML Editor code on your page, find the following line:
$CKEditor_config["tabSpaces"] = 4;
and change it to:
$CKEditor_config["enterMode"] = "CKEDITOR.ENTER_BR";
2) In the HTML Editor wizard, click the pencil icon next to the Editor Preset list to edit the preset, go to the Styles tab.
click the plus button to select a css style sheet, then change the body class to the class that you would like to use for body of the HTML editor window.
nickj
KFM editor
Regarding the background color of the editor as well as the default font color.
On our card site the client picks a e-card template which has a colored background. Some of the backgrounds have dark colors so I would like to have the editor have the same color background and have a different font color if appropriate. I would like to set a session for the background color and a session for the font color the pass these to the style sheet which the editor will use!
Where is the editor style sheet?
Can the Style Sheet be updated via a session variable?
this is not supported in HTML Editor, I think the best way to go about this is to create a unique page for each HTML Editor and set the background color statically, then include the HTML Editor instances as a Dynamic plugin using Framework builder, this way the session variable chooses which HTML Editor file to include.
nickj
That's fine but where is the contents.css file called?
In my instance I have tried to calll a file called contentsGRAY.css but it still used contents.css
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".$_SESSION['tbody'] ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "webassist/ckeditor/";
$CKEditor_config["contentsCss"] = "contentsGRAY.css";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "No File Management no imgae (custom)";
$CKEditor_config["wa_preset_file"] = "(custom)";
$CKEditor_config["width"] = "450px";
$CKEditor_config["height"] = "200px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["uiColor"] = "#999999";
$CKEditor_config["docType"] = "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\" \"http://www.w3.org/TR/html4/loose.dtd\">";
$CKEditor_config["contentsLanguage"] = "";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["toolbar"] = array(
array( 'Source'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-'),
array( 'NumberedList','BulletedList','-','Outdent','Indent'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Table','HorizontalRule','Smiley','SpecialChar','PageBreak','Maximize'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor_config["stylesCombo_stylesSet"] = "my_styles:style_lists/stylelist1.js";
$CKEditor->editor("tbody", $CKEditor_initialValue, $CKEditor_config);
thanks
nick
the html editor code doesn't call the css file directly.
it populates the style select list using the style_lists/stylelist1.js file:
nickj
I tried changing this file as well with no real effect. I think what we need to change the Automatic font color. The problemis that it has to be reflected in the html output which is stored in the DB.
This will taker custom development to accomplish, HTML Editor does not offer support for dynamically setting the font color. I would suggest signing up for a premiere support appointment if you need assistance with creating this.
