Discount Rate Not Showing Properly
Thread begun 5/22/2012 7:33 am by Magega49 | Last modified 5/22/2012 10:09 am by Magega49 | 4657 views | 9 replies |
Magega49
Hello,
Can you please help me on how to correct my discount cart I have create..
My discount is showing at all the time in my shopping cart it is suppose to show only when discount is applied.
Here you can see an example, ecart_shopping_cart.php
I'm assuming that you mean the line that shows the discount amount:
Discounts Free Domain Registration ( Starter Package )... -$0.00
is always showing?
for this you would add an if statement:
<?php if ($yourCart->GetDiscounts() > 0) { ?>
<?php ?>
where yourCart is the name of your eCart object.
Magega49
Discount
Yess, you got it man, but now I dont know where to place those code you just sent me... After I place than my page look broken?
Magega49
Error
Jason this is the error Im getting...
Fatal error: Call to a member function GetDiscounts() on a non-object in /home/magega49/public_html/ecart_shopping_cart.php on line 236
did you change "$yourCart" to use the name of your cart object?
I'll need a copy of the ecart_shopping_cart.php page to see the code.
Magega49
Name
O yes I just saw that.. I change the ecart_host name and is working fine... Thanks...
But there is one more thing that is not showing 100% the amount is not showing but the total amount has been applied a discount rate... please look at it..
i dont follow. how is a discount supposed to apply?
I will still need a copy of the ecart_shopping_cart.php page to look at the code.
Magega49
Page codes
Here is a copy of my page...
change this code:
<?php if ($Hosting_Services->GetDiscounts() > 0) { ?>
<span class="Gree_18Pts">Discounts  Free Domain Registration </span> <span class="Green_16_pts">-<?php echo WA_eCart_DisplayMoney($Hosting_Services$Hosting_Services->RuleLooperValue("Discounts")); ?></span><?php ?>
<span class="Gree_18Pts">Discounts  Free Domain Registration </span> <span class="Green_16_pts">-<?php echo WA_eCart_DisplayMoney($Hosting_Services->GetDiscounts()); ?></span><?php ?>
Magega49
Re:
Great thank you...
