Framework Builder Select Plugin Issue
I am using CS6 with Mac OSX.6. Whenever I try to add a plugin and use the directory select button, the window appears to select the plugin but it won't close. I then need to force quit Dreamweaver to carry on working.
I have a similar issue with with Image Resizer where there is an error when you select the directory button.
