Delete Popup Window
Thread begun 5/20/2012 6:33 am by bill173836 | Last modified 5/24/2012 11:05 am by Jason Byrnes | 6257 views | 12 replies |
bill173836
Delete Popup Window
I need to add a Delete button to a page. How is it possible to add a popup window like is generated for the _results.php page that says This will permanently remove the record from your database. This action cannot be undone. with buttons?
Also where do you adjust where the box is located? On mine it always appears at the bottom of the page instead of the middle of the page.
the delete popup window is done using 2 divs that are set to display: none by default.
the first div is an overlay that shows the grey screen in the background, the second div contains the delete form which has a delete button and a hidden form element in it that is used to pass the ID of the record to delete.
the delete button in the results page uses an onClick event to change the ID of the hidden element, and change the display property of the 2 hidden divs:
for example, the delete button on a page i created for a users table looks like this:
onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAUsers['UserID']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';"
and the delete form that is created looks like this:
<div class="black_overlay" id="deleteBox"></div>
    <div class="messageContainer" id="deleteMessage">
        <div class="messageWrapper">
          <div class="messageContent">
            This will permanently remove the record from your database.<br/>
            This action cannot be undone.<br/><br/>
            <input type="submit" value="Delete" class="formButton unstyled" id="Delete" name="Delete" />
            <input type="button" value="Cancel" class="formButton unstyled" id="Cancel" name="Cancel" onclick="document.getElementById('deleteBox').style.display = 'none';document.getElementById('deleteMessage').style.display = 'none';"  />
          </div>
      </div>
    </div>
the initial CSSS for the black_overlay and messageContainer classes uses display: none; to hide them till the delete button is clicked.
the css for the messageWrapper class should use absolute positioning and top: 50%; to position it in the middle of the page.
bill173836
I put this code inside the form tags of the form that is being submitted correct or the Delete button won't show up as submit option in the server behavior submit list?
the code I gave was an example, not the exact code that you should be using.
you need to create this functionality your self, using your own code, or you would be better of letting the wizard create it for you.
bill173836
How do you use the wizard to create the code on a page other than the results or detail page. I want it on the update page as the user only gets access to an update page?
the wizard will only add the delete button to the detail or results pages, it will not add the button to the update page, you will need to do this manually.
like i said, the code I gave was an example of how it is done on the results pages that i created.
you will need to modify the code to fit your pages, using the correct recordset references and correct css.
what i would do is first worry about creating a form that deletes the record, then worry about making it a popup using CSS.
bill173836
I created the file then I added the code. Now I get the pop up delete window in 2 separate locations. I've sent a zip file that includes 2 screen shots of the same size window so you can see what is happening. The CSS file that has the css code for the pop up. And the two php files that display the screen captures. Why is the pop up window high on the page in one and low on the page in the other. Shouldn't it be in the center of the page on both?
bill173836
Forgot the attachment.
you have the overlay and container divs as part of the main page div.
they should not be part of the main page div. the messageWrapper class should use absolute positioning and top: 50%; to position it in the middle of the page.
bill173836
Okay it appears this happens whenever I apply a template to the page. How do I get it so that it is not affected by the template. All the body code goes into the body region of the template. A page that doesn't use a template centers the popup but once the template is applied then the popup goes down below.
