ECart5 clear cart after success
Thread begun 5/18/2012 2:29 pm by sjuno299871 | Last modified 5/22/2012 8:11 am by Jason Byrnes | 4551 views | 9 replies |
sjuno299871
The customers info is not clearing out of the cart. Is ther a way to be sure that the cart is clered out after sucess?
add this code to the success page after the closing </html> tag
sjuno299871
code?
No code here
sjuno299871
I found this code used it on checkout success page after the closing </html> tag
Sorry not really up on PHP. My was session already started ignoring start session error. Did not update and no email of order. Just for fun(agony).. I took out Initialize the session part but still got errors. I am using a template and it told me I was adding it to
</body>
<!-- InstanceEnd --></html> HERE?
Code I used
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
@session_regenerate_id();
send a copy of the success page in a zip archive please
sjuno299871
zippy
Here is the file is it the params?
change line 82:
session_start();
@session_start();
sjuno299871
Then I got this?
Warning: Cannot modify header information - headers already sent by (output started at /home/content/32/7464632/html/impressionscustomapparel/checkout_success.php:23) in /home/content/32/7464632/html/impressionscustomapparel/checkout_success.php on line 94
sjuno299871
Worked on my workstation
Got that last error message on the ISP server?
this error occurs if there is output between php tags.
the error is reporting the problem at line 23.
see this post for details on troubleshooting and fixing this error:
showthread.php?t=19285
